HOW TO
This article shows how to label the selected features in ArcMap using VBA and ArcObjects.
For information on creating a UIControl, see the ArcGIS Desktop Help topic "How to create custom commands with VBA."
Code:
'Get the focus map
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pMap As IMap
Set pMap = pDoc.FocusMap
' Get the selected layer
Dim pLayer As IGeoFeatureLayer
Set pLayer = pDoc.SelectedLayer
' Make sure a layer was selected
If pLayer Is Nothing Then
MsgBox "You must select a Layer to Label"
Exit Sub
End If
' Get the feature class to get the correct
' oid field name for the data type (oid,fid,objectid)
Dim pFc As IFeatureClass
Dim strOIDName As String
Set pFc = pLayer.FeatureClass
strOIDName = pFc.OIDFieldName
' Get the selected features from the layer
Dim pFSel As IFeatureSelection
Set pFSel = pLayer
Dim pSelSet As ISelectionSet
Set pSelSet = pFSel.SelectionSet
Dim pFCur As IFeatureCursor
pSelSet.Search Nothing, False, pFCur
' Loop through the selected features and create a label
' expression for the selected features
Dim pFeat As IFeature
Dim strSql As String
Set pFeat = pFCur.NextFeature
Do While Not pFeat Is Nothing
If strSql = "" Then
strSql = strOIDName & " = " & pFeat.OID
Else
strSql = strSql & " or " & strOIDName & " = " & pFeat.OID
End If
Loop
Debug.Print strSql
' Get AnnotateLayerPropertiesCollection from layer
Dim pAnnoLayerPropsColl As IAnnotateLayerPropertiesCollection
Set pAnnoLayerPropsColl = pLayer.AnnotationProperties
Dim pAnnoLayerProps As IAnnotateLayerProperties
pAnnoLayerPropsColl.QueryItem 0, pAnnoLayerProps, Nothing, Nothing
pAnnoLayerProps.Class = "LabelSel"
pAnnoLayerProps.WhereClause = strSql
' Display the lables
pLayer.DisplayAnnotation = True
' Refresh the Data Frame
pDoc.ActiveView.Refresh
Article ID:000004723
Get help from ArcGIS experts
Download the Esri Support App
