HOW TO
Label or style a feature layer with a range of percentages using ArcGIS Arcade in Map Viewer
First Published: May 8, 2024
Last Published: May 10, 2024
Summary
In ArcGIS Online and Portal for ArcGIS Map Viewer, it is helpful to style or label numeric data in a feature layer using a range of percentages for better data management. In this article, an Arcade expression is used to create labels or style a feature layer with the desired range of percentages.
Procedure
Display the percentage range with labels
  1. Open the web map in Map Viewer and select the feature layer.
  2. On the Settings (light) toolbar, click Labels Labels icon.png. Enable the labels by toggling Enable labels on.
  3. In the Label features pane, click Add label class. Under Label field, click Use expression Use expression icon.png.
  4. In the editor window, configure the expressions below.
    1. Replace <variable_name> with the desired variable name. In this example, 'ratio' is used.
    2. Replace <field_name> with the field's name to display the range of percentages with labels. In this example, 'Accident_Ratio' is selected.
    3. Replace <field_value> with the desired field’s values from the attribute table.
    4. Replace <range of percentages> with the desired text for the labels.
var <variable_name> = $feature.<field_name>
if (<variable_name> <=<field_value>) {
    return "<range of percentage>";
} else if (<variable_name> <=<field_value> ) {
} else {
The numbers for the range can be specified as per the requirements of the field’s attribute value.
  1. Click Done.
Label expression configured with Arcade expression.
The web map below shows the range of percentages for the field displayed with labels.
Display the range of percentages with unique symbols
  2. On the Settings (light) toolbar, click Styles Styles icon.png.
  3. In the Styles pane, for Choose attributes, click Expression.
    2. Replace <field_name> with the field's name to display the range of percentages. In this example, 'Accident_Ratio' is selected.
    4. Replace <range of percentages> with the desired text for the legend.
} else {
  1. Click Done.
  1. In the Styles pane, for Pick a style, select Types (unique symbols).
  2. In the Styles pane, click Done.
  3. Display the legend representing the range of percentages for the values of the field. Refer to ArcGIS Online: View a legend (Map Viewer) or Portal for ArcGIS: View a legend (Map Viewer) for instructions.
The web map below shows the range of percentages represented through the unique symbols in the legend.
Web map displaying percentage range of field values with unique symbol style.png
Article ID: 000032559
Software:
  • Online
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
