HOW TO
Label decimal values as percentages using Arcade expression in ArcGIS Pro
Last Published: July 4, 2024
Summary
In some instances, an attribute value in percentage is written in decimal values when displayed as labels in ArcGIS Pro. In this article, an Arcade expression is used to convert the decimal values to percentages and display the percentages in labels. In this example, the Crime_rate field is used to display the percentages as decimal values.
The image below displays the labels with decimal values in ArcGIS Pro.
Map with decimal labels
Procedure
  1. Open the ArcGIS Pro project, add the layer, and create a label expression. Refer to Steps 1 through 4 in ArcGIS Pro: Writing a label expression for instructions. Select Arcade for Language.
In the Contents pane, on the List By Labeling tab, ensure the selected feature layer and feature class check boxes are checked to display the labels.
Labeling list in the Contents pane
  1. Insert and configure the expression below in the Expression box:
'<text>' + Round($feature.<field_name>*100, <decimal>) + "%"
  1. Replace <text> with the desired text to precede the field values. In this example, ‘The percentage of crime rate:’ is used.
  2. Replace <field_name> with the name of the field to be displayed as labels. In this example, the name of the field is Crime_rate.
  3. Replace <decimal> to round the percentage to the desired number of decimal places. In this example, the percentage is rounded to two decimal places by using '2'.
  1. Click the Verify button to validate the expression.
  2. Click Apply to run the script.
Expression configured in label class window
The image below displays percentage labels with preceding text in ArcGIS Pro.
Map displaying percentage labels
Article ID: 000030197
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
