HOW TO
Iterate network topology validation and subnetwork update using ArcPy in ArcGIS Pro
First Published: October 22, 2025
Last Published: April 22, 2026
Summary
In ArcGIS Pro, the Validate Network Topology and Update Subnetwork geoprocessing tools are used to manually validate features with dirty areas in the network topology and update subnetworks in ArcGIS Utility Network. This article describes a workflow to iterate these operations using ArcPy in ArcGIS Pro, enabling them to be executed repeatedly by applying iteration in the Python code.
Procedure
• Ensure the ArcGIS Utility Network license is assigned to the organization to enable ArcGIS Utility Network functionality.
• Ensure the ArcGIS Pro user license is Standard or Advanced. Refer to ArcGIS Pro: ArcGIS Pro license levels for more information.
  1. Open the ArcGIS Utility Network project in ArcGIS Pro.
  2. On the View ribbon tab, in the Windows group, click Python Window.
The Python Window button in the Windows group
  1. In the Python window, copy and paste the code below to automate the validation of network topology and update of subnetwork for ArcGIS Utility Network using ArcPy.
  1. Set the workspace to the geodatabase that contains the utility network dataset used in the project.
import arcpy
arcpy.env.workspace = (
    r"C:<geodatabase_path>"
  1. Select a feature class from the utility network.
fc = "utility network feature class"   # Utility network feature class containing lifecyclestatus field
field_name = "lifecyclestatus"    # field to toggle
oid_to_update = Object_ID                # OBJECTID of the Utility Network feature to update (in number)
  1. Retrieve the current project and active map.
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.activeMap
  1. Match the utility network name with the utility network layer in the Contents pane.
utility_network = m.listLayers("Utility_Network_Name")[0]
print(f"Using Utility Network layer: {utility_network.name}")
  1. Specify the domain network, tier, and subnetwork to be updated.
domain_network = "domain_network"
tier_name = "tier"
subnetwork_name = "subnetwork_name"
  1. Validate the network topology.
for iteration in range(1):  # this range of iteration depends on the user's testing requirements, the range number is flexible
    # Toggle lifecycle status on the selected switch
    with arcpy.da.UpdateCursor(
        fc,
        [field_name],
        f"OBJECTID = {oid_to_update}"
    ) as cursor:
        for row in cursor:
            # Toggle between two valid lifecycle values
            row[0] = 4 if row[0] == 0 else 0
            cursor.updateRow(row)
    print(f"Iteration {iteration + 1}: lifecycle status updated")
    # Validate Network Topology
    arcpy.un.ValidateNetworkTopology(
        utility_network,
        "DISPLAY"
    print("Network topology validated")
  1. Update the subnetwork.
    try:
        arcpy.un.UpdateSubnetwork(
            in_utility_network=utility_network,
            domain_network=domain_network,
            tier=tier_name,
            all_subnetworks_in_tier="SPECIFIC_SUBNETWORK",
            subnetwork_name=subnetwork_name,
            continue_on_failure="STOP_ON_FAILURE"
  1. Display the console output for each iteration.
print(f"Subnetwork '{subnetwork_name}' updated")
    except arcpy.ExecuteError:
        # Expected case when the subnetwork is already clean
        print(f"Subnetwork '{subnetwork_name}' is already clean (not dirty)")
    print("-" * 50)
print("All iterations completed successfully.")
The following code shows a sample of the full script.
import arcpy
# Set workspace to the Utility Network file geodatabase
    r"C:\Users\george\Documents\ArcGIS\Packages\Electric Utility Network_000\commondata\electric_utility_network.gdb"
# Utility Network feature class and field used to stimulate an edit
fc = "Electric Junction Object"   # base UN class
oid_to_update = 51                # chosen Switch OBJECTID
# Access the current ArcGIS Pro project and active map
m = aprx.activeMap
# Get the Utility Network layer from the map by name
utility_network = m.listLayers("ElectricNetwork Utility Network")[0]
# Details of the subnetwork to be updated
domain_network = "Electric"
tier_name = "Electric Distribution"
subnetwork_name = "Essential 003"
# Loop through repeated edit and subnetwork update operations
for iteration in range(5):  # start small
    # Toggle the lifecycle status to introduce and edit
        fc,
        [field_name],
    ) as cursor:
        for row in cursor:
    # Validate the Utility Network Topology
        utility_network,
        "DISPLAY"
    # Update the specified subnetwork
    try:
            tier=tier_name,
        # Display message if subnetwork is not dirty
    print("-" * 50) # print 50 hyphens (only to improve readability)
  1. Press Enter twice to execute the Python code.
The output displays each iteration of the network topology validation and subnetwork update processes, as shown below.
The successful iteration of network topology validation and subnetwork update processes
Article ID: 000038698
Software:
  • ArcGIS Pro
  • ArcGIS Utility Network
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
