HOW TO
Use the following article to install the 9.0 ArcGIS License Manager on a UNIX machine that is already hosting an 8.x ESRI License Manager. Before the installation of ArcGIS 9.0, verify that version 8.x of the ESRI License Manager has been installed and configured. If not, see the License Manager Reference Guide on the ArcInfo Workstation 8.x CD for more information.
Note:Installation of the 9.0 ArcGIS License Manager is required. Adding the 9.0 license file information to the existing 8.x license.dat in an 8.x $ARCHOME/sysgen directory does not work. Obtain a 9.0 license file from ESRI Customer Service for the 9.0 version of the License Manager.The two vendor daemons cannot use the same port. By default, the 9.0 ARCGIS daemon is set to 27004 and the 8.x ESRI daemon is set to 27005.The two versions of the License Manager must be installed to separate directories.
This information refers only to the License Manager software. For information on software installation, see the appropriate installation guide.
Code:
% hostid
% hostname
SERVER hostname hostid 27004
Code:
% ./lmgrd -c license.dat > /dev/console &
Code:
% ./lmutil lmstat -a -c license.dat
Code:
setenv ARCGIS_LICENSE_FILE @<host>
setenv ARCGIS_LICENSE_FILE <port>@<host>
Article ID:000006596
Get help from ArcGIS experts
Download the Esri Support App
