HOW TO
Insert special characters between text field values using the Calculate Field tool in ArcGIS Pro
First Published: May 18, 2023
Last Published: April 14, 2026
Summary
In ArcGIS Pro, special characters can be added to the text field values in an attribute table to emphasize, split, or provide distinction to the values of the field. This can be achieved using Python in the Calculate Field window.
Apply the workflow provided to insert characters into an existing field using the Calculate Field tool.
In this article, the special character ',' is added to the field values to improve data readability.
The attribute table fields.
Procedure
This calculation can only be applied to text fields because special characters are only supported in the Text data type field.
  1. Open the project in ArcGIS Pro.
  2. In the Contents pane, right-click the layer and click Attribute Table to open the layer's attribute table.
The Attiribute Table option.
  1. In the attribute table view, click the Add Field The Add Field icon. icon to add a field.
    1. In the Fields view, in the Field Name column, specify a name for the new field. In this example, the new field name is 'Sales3'.
    2. Under the Data Type column, double-click the cell to open the drop-down menu and click Text.
    3. On the Fields tab, in the Manage Edits group, click Save. Close the Fields view.
  2. In the attribute table, right-click the newly added field and click Calculate Field. The Sales3 field is used in this example.
The Add Field icon.
  1. Populate the field with the values from the intended field to add the special character. In the Calculate Field window, configure the parameters.
    1. For Input Table, ensure the layer selected in Step 2 is prefilled. In this example, the input table is Sheet1_XYTableToPoint.
    2. For Field Name (Existing or New), ensure the selected field name is prefilled. Otherwise, select the field from the drop-down menu. In this example, the field name is Sales3.
    3. For Expression Type, select Python.
    4. For Expression, in the expression box, type the code provided below. Replace 'Field name' with the name of the field to be cloned. In this example, the Sales2 field is cloned.
!Field name!
  1. Click OK.
The OK button in the Calculate Field window.
  1. In the attribute table, right-click the newly added field and click Calculate Field. The Sales3 field is used in this example.
The Add Field icon.
  1. Add the special character to the field values. In the Calculate Field window, configure the parameters.
    4. For Expression, in the expression box, type the code provided below. Replace 'Field name' with the selected field name in Step 7(b), and 'Insert a special character' with the preferred special character.
!Field name![0:3] + "Insert a special character" + !Field name![3:]
  1. Click OK.
The Calculate Field tool permanently modifies inputs by changing values in the attribute fields. To avoid having permanent changes applied, toggle Enable Undo on in the Calculate Field window before running the tool.
The Calculate Field window.
The attribute table below shows the special character ',' applied to the field.
Article ID: 000030148
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
