HOW TO
In ArcGIS Online, a record can be manually inserted into a relationship table to create a relationship between records in the origin and destination tables. Alternatively, ArcGIS API for Python can be used to programmatically insert the records using primary key values. As a result, new records containing the corresponding foreign key values are added to the relationship table, creating relationships between the associated records in the origin and destination tables.
This article describes the workflow to insert records into a many-to-many relationship table using ArcGIS API for Python in ArcGIS Notebooks.
from arcgis.gis import GIS
from arcgis.features import FeatureLayer
gis = GIS("home")
Note: After pasting the code, click Run this cell and advanceto execute the cell before proceeding to the next step.
relationship_table = FeatureLayer(
"<URLofFeatureService>",
gis
result = relationship_table.edit_features(
adds=[
"attributes": {
"<originTableForeignKey>": "<originTablePrimaryKey>",
"<destinationTableForeignKey>": "<destinationTablePrimaryKey>"
"attributes": {
"attributes": {
relationship_table_name = relationship_table.properties.name
if result["addResults"][0]["success"]:
print(
f"Relationship record created successfully. "
f"A new record has been added to the {relationship_table_name} table."
else:
print("Failed to create relationship record.")
print(result)
latest_record = max(
relationship_table.query(
where="1=1",
out_fields="*"
).features,
key=lambda f: f.attributes["<ObjectIDFieldName>"]
print(latest_record.attributes)
The code below shows the full working script.
gis = GIS("home")
"https://services9.arcgis.com/LMuydzYxR6YWiqk2/arcgis/rest/services/Relationship_Table/FeatureServer/3",
gis
adds=[
"attributes": {
"ProjectGUID": "bfff21b8-e352-40be-87dc-c46f24fb8c32",
"EmployeeGUID": "713588da-ee1b-4bd0-95bd-e69dc6020fe5"
"attributes": {
"EmployeeGUID": "8760b436-664a-4430-b312-cf38f375a293"
"attributes": {
"ProjectGUID": "bec6b0e8-2d45-4bcb-b650-5812d6448a5c",
print(
else:
print(result)
where="1=1",
out_fields="*"
).features,
key=lambda f: f.attributes["RID"]
The table below displays the inserted records.
Article ID: 000042945
Get help from ArcGIS experts
Start chatting now
