HOW TO
Increase the maximum altitude in ArcGIS Flight
Last Published: December 10, 2024
Summary
By default, the maximum altitude for ArcGIS Flight is 190 meters. In some use cases and where flying regulations are met, it may be necessary to increase this.
Procedure
To increase the maximum altitude in ArcGIS Flight follow the steps below:
  1. Open and sign in to ArcGIS Flight on the iPad.
  2. Select Global Settings (upper-right gear icon) and in the highlighted area of the Global Settings dialog box, using two fingers, tap three times quickly (as fast as you can).
If done correctly, the Developer Info option appears, as shown in the next image.
  1. Select Developer Info and scroll to Survey Defaults, as shown in the next image.
  2. Change the maximum altitude to the desired height.
    • Ensure that the flight height in the DJI Main Controller settings are also updated if needed.
Article ID: 000027519
Software:
  • Mobile Applications
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
