Summary
When generating feature reports from ArcGIS Survey123, the images attached in the survey forms are of low quality. This article describes the workflow to improve the quality of the images in ArcGIS Survey123 feature reports.
The following example image is an image with low quality in an ArcGIS Survey123 feature report.
Procedure
- Open the desired survey form in the ArcGIS Survey123 website, and download the sample template. Refer to ArcGIS Survey123: Report templates.
- Open the downloaded sample template, and navigate to the image section.
- Add getValue:"" to the expression. In this example, getValue:"" is added to the expression in the picture section.
- Save the changes.
- In the ArcGIS Survey123 website of the desired survey, click Data > Report > Manage templates.
- In the Manage Templates window, click New template to upload the edited template.
- Close the Manage Templates window, and generate the feature reports.
The following image displays the example image with improved quality in an ArcGIS Survey123 feature report.
