HOW TO
Import Microsoft Excel table data with field lengths greater than 255 to a file geodatabase
First Published: May 5, 2016
Summary
Microsoft Excel table data with field lengths greater than 255 characters can be imported to a file geodatabase. However, ArcMap converts these fields into a binary large object (BLOB) field type, and data converted into a BLOB type is not readable by ArcMap. This is currently a known limitation.
No alternative workaround exists for versions prior to ArcMap 10.1.
Procedure
The instructions below describe how to import Microsoft Excel table data with field lengths greater than 255 to a file geodatabase.
  1. Save the Excel table as a tab-delimited text file or CSV file by navigating to File > Save As > Save As Type.
  2. In ArcMap, navigate to ArcToolbox > Conversion Tools > To Geodatabase > Table to Table.
  3. In the Table to Table dialog box, for Input Rows, select the tab-delimited text file or CSV file from step 1.
  4. For Field Map, right-click the field containing the long text values, and select Properties.
  5. In the Output Field Properties dialog box, change Length to a value that accommodates the desired length.
Image of the table to table tool window
  1. Click OK to begin the conversion.
Article ID: 000012617
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
