HOW TO
Instructions provided describe how to import coverage or SDE 3 annotation into a geodatabase. If ArcGIS Desktop version 9.0 or later is used, the ArcToolbox Geoprocessing tool 'Import Coverage Annotation' can be used to import coverage or SDE 3 annotation to geodatabase annotation. For additional help with this, see the ArcGIS Desktop Help topic "Importing coverage of CAD annotation into geodatabase annotation".If ArcGIS Desktop version 8.3 or prior is used, ArcMap's 'Convert Coverage Annotation' tool can be used to convert coverage or SDE 3 annotation to geodatabase annotation. An annotation feature class in a geodatabase is required to store the converted annotation. Create a new annotation feature class using ArcCatalog, if necessary.
Create a new annotation feature class in ArcCatalog, if necessary. If converting to feature-linked annotation when creating a new new annotation class, specify a default text symbol and an annotation reference scale. This text symbol should be the same as the symbol used to symbolize the coverage annotation in ArcMap. The reference scale should be the scale at which the annotation is converted.
It is possible to convert multiple coverages or SDE 3 annotation classes simultaneously, but they will all be converted into a single geodatabase annotation feature class. All converted annotation will have the same reference scale, because all annotation in a geodatabase annotation feature class has the same reference scale. To learn more about annotation reference scales, see 'Converting labels to annotation' in the ArcGIS Desktop Help.
Article ID:000005940
Get help from ArcGIS experts
Download the Esri Support App
