HOW TO
Import certificates to ArcGIS Server and Portal for ArcGIS using Python
First Published: December 15, 2022
Last Published: May 23, 2023
Summary
A server certificate is a digital file containing information about the identity of the web server and is used to authenticate the server's identity to the client. Instead of importing server certificates through the REST endpoints of the Portal Administrator Directory and the ArcGIS Server Administrator Directory, the Python scripts provided in this article can also be used to import existing certificates to Portal for ArcGIS and ArcGIS Server.
Procedure
Depending on the product, use one of the Python scripts below to import existing server certificates.
Portal for ArcGIS
  1. Import the necessary modules.
import arcgis
  1. Specify the credentials and define the ssl parameter.
gis = arcgis.GIS("https://hostname.domain.com/portal","<username>","<password>")
ssl = gis.admin.security.ssl
  1. Import the certificate and update the necessary properties.
ssl.import_server_certificate("<certificateAlias>", "<privatekey>",
r"<filepath>.pfx")
ssl.update("<certificateAlias>", ssl.properties["<sslProtocols>"], ssl.properties["<cipherSuites>"])
The Python script below is the full sample script to import an existing server certificate to Portal for ArcGIS and update the web server certificate alias.
import arcgis
gis = arcgis.GIS("https://testserver.esri.com/portal","adminuser","adminpassword")
ssl.import_server_certificate("TestCert", "cer46s5ae1fr98r",
r"C:\Users\USER\Desktop\Cert\Cert.pfx")
ssl.update("TestCert", ssl.properties["TLSv1.2"], ssl.properties["TLS_RSA_WITH_AES_128_CBC_SHA"])
ArcGIS Server
from arcgis.gis import GIS
from arcgis.gis.server import Server
  1. Specify the credentials and define the hosting server URL.
gis = GIS(url="https://hostname.domain.com/portal", username="<username>", password="<password>")
urlHosting = "https://hostaname.domain.com/server"
hostingServer = Server(url=urlHosting, gis=gis)
  1. Define the path for the certificate.
cert= r"<filepath>.pfx"
  1. Import the certificates.
for machine in hostingServer.machines.list():
    machine.import_existing_server_certificate("<cerificateAlias>","<privatekey>", cert)
The Python script below is the full sample script to import an existing server certificate to ArcGIS Server. Unlike Portal for ArcGIS, there is no documented way to update the ArcGIS Server web server certificate alias using ArcGIS API for Python.
gis = GIS(url="https://testserver.esri.com/portal", username="adminuser", password="adminpassword")
urlHosting = "https://testserver.esri.com/server"
cert= r"C:\Users\USER\Desktop\Cert\Cert.pfx"
    machine.import_existing_server_certificate("TestCert","cer46s5ae1fr98r", cert)
Article ID: 000029033
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
