HOW TO
Identify the database source of a service in ArcGIS Enterprise using API for Python
First Published: August 23, 2022
Last Published: March 5, 2025
Summary
A service can be published to ArcGIS Server from multiple sources, for example, from ArcGIS Pro or direct file uploads to Portal for ArcGIS. Refer to ArcGIS Enterprise: Publish in ArcGIS Enterprise for more information. To identify a database source, users can manually check the manifest.json file in the following directory:
C:\arcgis\arcgisserver\config-store\services\<Service Folder>\<Service Name>\esriinfo\manifest
Another way to identify the database source of a service is using ArcGIS API for Python. This article provides the workflow to identify the database source of a service using a Python script.
Procedure
  1. Import the necessary modules.
from arcgis.gis import GIS
import pprint
  1. Specify the credentials for the portal and connect.
gis = GIS('https://<machine>.<domain>/<web adaptor name>', 'username', 'password', verify_cert=False)
print('Connected')
  1. List the available servers in the portal.
servers = gis.admin.servers.get(role="HOSTING_SERVER")
print(servers)
  1. Specify the folder containing the services and select the service. The following example demonstrates the first service in the folder.
server1 = servers[0]
services = server1.services.list(folder="<Folder Name>")
service = services[0]
  1. Get the service information and properties, and return the result in the console.
ii = service.iteminformation
manifest = ii.manifest
pprint.pprint(manifest)
properties = ii.properties
pprint.pprint(properties)
The code block below demonstrates the full working script.
import pprint
gis = GIS('https://machine.esri.com/portal', 'username', 'password', verify_cert=False)
print('Connected')
print(servers)
services = server1.services.list(folder="Test_Folder")
Article ID: 000028180
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
