HOW TO
Have a fixed scale symbology in ArcGIS Pro
Last Published: June 12, 2024
Summary
In ArcGIS Pro, the scale of symbol classes can be fixed to limit the amount of detailed data drawing at different scales. This article provides the steps to apply a fixed scale symbology based on the applied reference scale of a map in ArcGIS Pro.
Procedure
  1. Start ArcGIS Pro and open the project.
  2. In the Contents pane, right-click the map and click Properties to open the Map Properties dialog box.
  3. Click General and select the required Reference scale.
  4. Click OK.
Setting up the reference scale to 1:100,000 in the ArcGIS Pro Map Properties dialog box
  1. In the Contents pane, right-click the feature layer and click Properties to open the Layer Properties dialog box.
  2. Click Display and check the Scale symbols when a reference scale is set check box.
  3. Click OK.
Checking the Scale symbols when a reference scale is set check box in the ArcGIS Pro Layer Properties dialog box
Article ID: 000019184
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
