HOW TO
Get parameters for the Export Map Image request in REST for a map service with dynamic layers
First Published: March 2, 2017
Summary
It is possible to allow clients of the server, such as the ArcGIS Web APIs, to dynamically change the layer appearance and behavior of the map service when publishing a map service to the ArcGIS Server site.
Dynamic layer-enabled services within custom applications and test requests at REST allow users to preview the application. This can be done with the Export Map function. However, to perform the action, users are prompted to input parameters before submitting the request.
Procedure
To get the values for the parameters, modify the service in the ArcGIS Online Map Viewer and retrieve the final values from the browser's Developer Tools. Follow the steps below:
  1. In the REST page of the map service, select ArcGIS Online Map Viewer to view the map.
    User-added image
  2. In the Contents pane, if necessary, modify the appearance of the service, such as changing the style.
    User-added image
    User-added image
  3. Once the service is formatted as desired, open the browser's Developer tools and click the Network tab.
To open the Developers tools in Google Chrome, click the Customize and control Google Chrome icon (three horizontal bars in the upper right corner) and click More tools > Developer tools.
  1. Pan or zoom around the map to the desired area. The list of requests is populated.
  2. Click the export request.
  3. In the Headers tab, navigate to the Query String Parameters section. This section has most of the parameters required to perform a REST request for Export Map Image (POST).
    Get parameters from the Query String Parameters
    User-added image
Article ID: 000015441
Software:
  • ArcGIS Online
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
