HOW TO
Georeference CAD data
First Published: May 6, 2016
Last Published: October 4, 2024
Summary
Georeferencing CAD data involves assigning a coordinate system and applying a transformation to the CAD data. The instructions provided describe how to georeference CAD data in ArcMap.
ArcMap is in Mature support and will be retired March 1, 2026. There are no plans for future releases of ArcMap, and it is recommended that you migrate to ArcGIS Pro. See Migrate from ArcMap to ArcGIS Pro for more information.
Procedure
Before georeferencing the CAD data, assign the desired projection to the map to which the CAD data will be referenced. The georeferencing process writes out the projection file for the newly georefenced CAD file.
Refer to FAQ: How do I define the projection for ArcGIS data? for more information.
  1. In ArcMap, add the CAD data to the map.
  2. Open the Georeferencing toolbar. Navigate to Customize > Toolbars > Georeferencing.
  3. On the toolbar, select the desired CAD feature layer from the dataset.
The Georeferencing toolbar displaying the selected CAD feature layer.
  1. Zoom to the desired destination area, and navigate to Georeferencing > Fit To Display.
The Georeferencing drop-down menu displaying the Fit To Display option.
  1. To create the first link, click the Add Control Points tool, and snap to the endpoint of the desired parcel feature.
The Georeferencing toolbar displaying the description of the Add Control Points tool and its icon.
  1. To save the updates, click Georeferencing > Update Georeferencing.
The Georeferencing drop-down list displaying the Update Georeferencing option.
The CAD World File window displays.
  1. In the CAD World File window, save the desired file name and file type as World.
  2. Click Save.
Article ID: 000012808
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
