HOW TO
Generate and use an ArcGIS Server token using Postman
First Published: March 24, 2021
Last Published: July 28, 2021
Summary
The following workflow discusses how to generate and use a token in a standalone ArcGIS Server site. This method works for GIS Server-tier authentication using both Windows and built-in user stores. For federated ArcGIS Server sites, tokens must be created through Portal for ArcGIS instead.
Procedure
  1. Launch Postman, and specify either the base generateToken URL for accessing services (https://gisserver.domain.com:6443/arcgis/tokens/generateToken), or the admin generateToken URL for administrative workflows (https://gisserver.domain.com:6443/arcgis/admin/generateToken).
Note
The Web Adaptor URL can also be used here. Leave the Params, Authorization, and Headers sections as default. In the Body section, select the x-www-form-urlencoded radio button, to encode the username and password used to access ArcGIS Server.
  1. Add the following key:value pairs in the Body section:
    • Username - The username for the ArcGIS Server account
    • Password - The password for the ArcGIS Server account
    • Client - There are three options for this: ip, referer, and requestip. In this example, we will use the referer value to specify a base URL for everywhere we want to use the token. See the below documentation for scenarios where using ip or requestip would be useful.
    • Referer - The base URL of the ArcGIS Server resource to access, such as :6443/arcgis or :6443/arcgis/admin.
    • Expiration - The length of time the token is active. This has a maximum value controlled by the lifespan settings found in Server Manager > Security.
The added key:value pairs in the Body section
  1. Click POST, and copy the resulting token.
  2. Compose a new request to the ArcGIS Server resource to access. For example:
:6443/arcgis/services/SampleWorldCities/MapServer
  1. In the Params tab, add the token and paste the actual token in the key:value pair.
The actual token pasted in the key:value pair in the Params tab.
  1. Leave the Authorization and Body tabs as default, and in the Headers tab, add a new key:value pair of referer, and the referer URL specified in the previous request. For all subsequent requests using the previously generated token, add this referer key:value pair as a Header in order for the token to be accepted. Send the POST request, and note that the token is honored.
The POST request uses the token with the set parameters and is accepted by ArcGIS Server, allowing access to the desired service.
Article ID: 000025198
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
