HOW TO
Generate a report of all items in Portal for ArcGIS and ArcGIS Online
Last Published: August 30, 2022
Summary
In an organization, managing and administrating large number of items stored within Portal for ArcGIS and ArcGIS Online can be time-consuming. To simplify this process using ArcGIS API for Python, the following steps describe how to generate a report of all items in Portal for ArcGIS or an ArcGIS Online organization.
Procedure
Choose one of the following scripts below.
Generate the report for all items in Portal for ArcGIS
  1. Import the necessary modules.
from arcgis import GIS
import pandas as pd
  1. Connect to the portal URL and specify the credentials.
gis = GIS('<machine>.<domain>/<web adaptor name>', 'username', 'password', verify_cert=False)
print("Connected")
  1. Search for all items available in the portal.
content_list = gis.content.search('owner:<Owner_Name>', max_items=-1)
  1. Create a dictionary containing all the items with the details such as title, type, owner, and id.
out_dict = {}
for item in content_list:
    out_dict[content_list.index(item)] = [item.title, item.type, item.numViews, item.owner, item.id]
df = pd.DataFrame.from_dict(out_dict, orient='index')
df.rename(columns={0:'title', 1:'type', 2:'views', 3:'owner', 4:'id'}, inplace=True)
  1. Export the dictionary to a table file such as .csv or .xls.
df.to_csv(r'<Folder Location>')
The following code block demonstrates the full script.
import pandas as pd
gis = GIS('machines.esri.com/portal', 'username', 'password', verify_cert=False)
print("Connected")
content_list = gis.content.search('owner:Test_User', max_items=-1)
type, owner, id, etc.
out_dict = {}
df.to_csv(r'C:\Users\USER\Desktop\TestListReport.csv')
Generate the report for all items in ArcGIS Online
import pandas as pd
gis = GIS('https://arcgis.com', 'username', 'password')
print("Connected")
content_list = gis.content.search('owner:username', max_items=-1)
out_dict = {}
import pandas as pd
print("Connected")
out_dict = {}
Article ID: 000028142
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
