HOW TO
Generate a random number within a range for labels in ArcGIS Pro
Last Published: April 26, 2024
Summary
In ArcGIS Pro, a random number within a range can be generated using Arcade expressions to label each feature on the map. This allows for a better visualization of the random classification on a map when performing predictive analysis.
This article provides an example and instructions using Arcade expressions to generate a random number within a range for labels in ArcGIS Pro.In this article's example, the TampaBuildings layer contains polygon features of buildings in Tampa.
The image below shows a map in ArcGIS Pro without random numbers on the polygon features.
The polygon features without random numbers on the map
Procedure
  1. Start ArcGIS Pro and open the project.
  2. In the Contents pane, right-click the feature class and click Labeling Properties... to open the Label Class pane.
The Contents pane in ArcGIS Pro
  1. In the Label Class pane, click the Label expression The Label expression icon button and configure the following parameters.
    1. For Language, select Arcade.
    2. Specify the following script in the Expression section.
Round(Random() * (<valueDigit1> - <valueDigit2>) + <valueDigit2> , <numberOfDecimal>)
The code block below is an example of the full working expression to generate a random round number between 0 to 50.
Round(Random() * (0 - 50) + 50 , 0)
  1. Click Verify to run a test of the expression. If the expression is valid, click Apply.
The Label Class pane in ArcGIS Pro
  1. In the Contents pane, right-click the feature class and click Label to enable labeling of the layer.
The image below displays the map with random numbers on the polygon features.
The map in ArcGIS Pro with randomized digit labels on each polygon
Article ID: 000030976
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 9x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
