HOW TO
Fly a multi-battery flight with Site Scan Flight for ArcGIS
Last Published: September 1, 2023
Summary
A single battery generally enables the survey of up to 50 acres, but with Site Scan Flight for ArcGIS, it is possible to split a flight between multiple batteries to survey larger areas. This feature operates automatically without any input from the user.
Procedure
When planning a survey, the Site Scan Flight app approximates the number of fully charged batteries the drone consumes to complete the flight. Below is an image of a planned a survey that will consume two batteries.
A planned survey that consumes 2 batteries
Take off as normal, note however, that the Flight app checks the battery before flying. If the battery is not fully charged, a battery capacity warning message is returned, as shown below. This warning provides the opportunity to swap out the battery for a fully charged one before taking off.
The battery capacity warning message
The drone flies the prescribed path capturing images along the way. Upon landing, the drone prompts for a battery change. Change the battery, or end the survey if it is no longer necessary to capture the remainder of the photos.
The replace battery message
After replacing the battery, while waiting for the drone to reconnect, the Flight app prompts for continuation of the survey.
This behavior occurs whether the survey was ended prematurely by the user, or the battery.
The Ready to Continue message
After tapping Continue Survey, swipe the Take Off slider to the right, and the drone continues to fly autonomously, capturing the aerial data.
The pre-flight checklist
Article ID: 000023057
Software:
  • Site Scan Flight for ArcGIS iPadOS
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
