HOW TO
Flagging AML errors with a beep
Procedure
Question:
Can an AML be made to beep whenever an error or end of routine is encountered?
Cause:
Not applicable
Answer:
On UNIX systems, AML can access the keyboard bell by using the "CTRL G" key sequence with the &TYPE directive. The following line can be added to any error checking routine:
&TYPE ^G
The '^G' is created by holding down the Ctrl key and holding down the shift key and pressing g. On the screen and in a text file, it will look like ^G. But it would be one character and not two, i.e, you will not get a beep if you put a ^ and a G next to each other.
You can create the ^G by:
Arc: &watch beep.wat
Arc: &type ^G /*press Ctrl + Shift + g
Arc: &watch off
Arc: &cwta beep.wat beep.aml
Article ID:000001353
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
