HOW TO
After upgrading ArcGIS Enterprise from version 11.5 to 12.1, the ArcGIS GeoEvent Server properties pane for input and output connectors may fail to load. As a result, users are unable to view or configure connector properties and may be unable to create or configure new GeoEvent input or output connectors.
The issue can occur when existing GeoEvent Server components and folders from the previous installation remain on the machine after the upgrade. Residual GeoEvent Server files or configuration components can conflict with the ArcGIS GeoEvent Server 12.1 installation, preventing the connector properties pane from loading correctly.
Perform a clean removal and reinstallation of ArcGIS GeoEvent Server.
Important consideration: If you deployed any custom components developed using the GeoEvent Server SDK, the associated *.jar files should be moved to a temporary folder location, outside the GeoEvent Server installation folder. Do this while GeoEvent Server is running and prior to executing the steps below.
Ensure that all folders and residual files related to the previous ArcGIS GeoEvent Server installation have been removed before proceeding with the new installation.
After performing the clean removal and fresh installation, the GeoEvent Server input and output properties pane loads correctly, allowing users to create and configure input and output connectors.
Article ID: 000043400
Get help from ArcGIS experts
Start chatting now
