HOW TO
Find the raster value differences between two raster images in ArcGIS Pro
Last Published: November 23, 2023
Summary
When two raster images geographically overlap, finding the difference in value between the two raster images can be useful for analysis. This article provides two workflows for ArcGIS Pro using the Raster Calculator and the Minus tools.
Procedure
The Raster Calculator and Minus tools require a Spatial Analyst license.
Use the Raster Calculator tool
  1. Open the ArcGIS Pro project.
  2. In the Geoprocessing pane, search for and click the Raster Calculator (Spatial Analyst Tools) tool. Refer to ArcGIS Pro: Run a geoprocessing tool for further instructions.
  3. In the Raster Calculator pane, configure the Parameters tab.
    1. For the Rasters parameter, double-click the first raster layer to add the layer to the expression box.
    2. For Tools, double-click the - operator.
    3. In the Rasters parameter, double-click the second raster layer to add the layer to the expression box.
    4. Provide a name for Output raster, and click Browse File icon. to specify a location for the output raster.
    5. Click Run.
The Raster Calculator (Spatial Analyst Tool) pane to be configured in ArcGIS Pro.
Use the Minus tool
  2. In the Geoprocessing pane, search for and click the Minus (Spatial Analyst Tools) tool. Refer to ArcGIS Pro: Run a geoprocessing tool for further instructions.
  3. In the Minus pane, configure the Parameters tab.
    1. Select the first raster layer from the Input raster or constant value 1 drop-down list.
    2. Select the second raster layer from the Input raster or constant value 2 drop-down list.
    3. Provide a name for Output raster, and click Browse File icon. to specify a location for the output raster.
    4. Click Run.
The Minus (Spatial Analyst Tool) pane to be configured in ArcGIS Pro.
Article ID: 000029253
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
