HOW TO
Find the path of least resistance down a DEM
Summary
Instructions provided describe how to find the path of least resistance down a DEM.
Procedure
Before beginning, make sure that the elevation model used for the procedure is a DEM with a projection in feet or meters, and that it is not a floating-point raster. Also, ensure that there are no negative values in the DEM. If there are negative values, remove them before running the procedures.
  1. Create a point feature that will be used to determine the source of the path.
  2. Run the Flow Direction tool to create a flow direction raster from the DEM.
  3. Use the Cost Path tool to generate the path of least resistance.
    -Specify the point feature as the 'Input raster or feature destination data'.
    -Specify the DEM as the 'Input cost distance raster'.
    -Specify the flow direction raster created in step 2 as the 'Input cost backlink raster'.
    -Specify an output raster. This symbolizes the path.
    -Specify 'EACH_CELL' as the Path Type.
Article ID: 000009935
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
