HOW TO
Find the date and time a service is published to ArcGIS Server
Last Published: November 4, 2022
Summary
It is sometimes necessary to access information on the date and time a service is published to ArcGIS Server when performing updates on the service. However, this information is not available in ArcGIS Server Manager. This article provides two workflows to find the date and time a service is published to ArcGIS Server.
Procedure
From the ArcGIS Server Administrator Directory
Follow this workflow to access information on the date and time a service is published, started, and last modified from the ArcGIS Server Administrator Directory.
  1. Sign in to the ArcGIS Server Administrator Directory.
  2. Under Resources, click services.
  3. On the Folder - / page, under the Services section, select the service.
  4. On the Service page of the selected service, scroll to the bottom of the page and click lifecycleinfos under Resources.
The Resources section on the Service page in the ArcGIS Server Administrator Directory.
Timestamps on when the service is published, started, and last modified are displayed in the LifeCycle Information section.
The LifeCycle Information section in the ArcGIS Server Administrator Directory.
From the service's metadata
When working offline, follow the workflow below to find the date and time a service is published. However, additional information on when the service is started or last modified is not available in the service's metadata XML document.
  1. On the machine, follow the file path below to access a service's metadata XML document.
C:\arcgis\arcgisserver\directories\arcgissystem\arcgisinput\<servicename>.<servicetype>\extracted\esriinfo\metadata\metadata.xml
The metadata XML document in File Explorer.
  1. In the folder, double-click the metadata XML document to access the metadata.
The date and time the service is published to ArcGIS Server are displayed in the <CreaDate> and <CreaTime> tags. The date is displayed in the YYYYMMDD format, and the time is displayed in the hhmmssss format.
The metadata.xml document opened in the Google Chrome browser.
Article ID: 000028704
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
