HOW TO
The following VBA code calculates the center point of a data frame. The coordinates are in the map units of the data frame.
Code in ThisDocument code module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
Code:
Sub ReturnCenter()
Dim pMxDoc As IMxDocument
Set pMxDoc = Application.Document
Dim pEnv As IEnvelope
Set pEnv = pMxDoc.ActivatedView.Extent
Dim pX As Double
Dim pY As Double
pX = (pEnv.XMax + pEnv.XMin) / 2
pY = (pEnv.YMax + pEnv.YMin) / 2
MsgBox pX & ", " & pY
End Sub
Article ID:000005582
Get help from ArcGIS experts
Download the Esri Support App
