HOW TO
This article provides a script to determine which tables in a project are joined or linked.
Code:
'---------------Begin Script------------------
'Will return a message box for each instance of a Join or Link
'The following information will be returned:From Table, To Table, From Field, To Field.
afn = filedialog.show("*.apr","AV Projects","")
lf = linefile.make(afn, #FILE_PERM_READ )
joinDict = dictionary.make(10)
linkDict = dictionary.make(10)
while(lf.isatend.not)
buf = lf.readelt
if((buf.contains("(Join.")))then
joinobj = buf.astokens(".").get(1)
fromt = lf.readelt.astokens(":").get(1).basictrim(TAB,"")
fromf = lf.readelt.astokens(":").get(1).basictrim(TAB,"")
tot = lf.readelt.astokens(":").get(1).basictrim(TAB,"")
tof = lf.readelt.astokens(":").get(1).basictrim(TAB,"")
joinlist = {fromt,fromf,tot,tof}
joinDict.add(joinobj,joinlist)
elseif(buf.contains("(Link.")) then
linkobj = buf.astokens(".").get(1)
linklist = {fromt,fromf,tot,tof}
linkDict.add(linkobj,linklist)
end
end
masterJoinList = {}
masterLinkList = {}
for each jlist in joinDict
newlist = {}
for each elem in jlist
lf.gotobeg
buf = lf.readelt
if((buf.left(1) = "(") and (buf.astokens(".").get(1) = elem)) then
'msgbox.info(buf,"")
newobj = lf.readelt.astokens(":").get(1).basictrim(TAB,"")
newlist.add(newobj)
end
end
end
masterJoinList.add(newlist)
end
masterLinkList = {}
for each llist in linkDict
newlist = {}
for each elem in llist
lf.gotobeg
buf = lf.readelt
newlist.add(newobj)
end
end
end
masterLinkList.add(newlist)
end
MsgBox.Info("This project contains"++masterJoinList.count.asstring++"joined table(s).", "Joined Tables")
Count = 1
for each l in masterJoinList
msgbox.listasstring({"TO TABLE:"++l.get(0).unquote, "TO FIELD:"++l.get(1).unquote, "FROM TABLE:"++l.get(2).unquote, "FROM FIELD:"++l.get(3).unquote},"Join Table"++count.asstring,"Joined Tables and their Fields")
count = count + 1
end
if (masterJoinList.isempty) then
msgbox.info("This project contains no Joins","")
end
MsgBox.Info("This project contains"++masterLinkList.count.asstring++"linked table(s).", "Linked Tables")
Count = 1
for each l in masterLinkList
msgbox.listasstring({"TO TABLE:"++l.get(0).unquote, "TO FIELD:"++l.get(1).unquote, "FROM TABLE:"++l.get(2).unquote, "FROM FIELD:"++l.get(3).unquote},"Link Table"++count.asstring,"Linked Tables and their Fields")
count = count + 1
end
if (masterLinkList.isempty) then
msgbox.info("This project contains no Links","")
end
'-----------------End Script--------------
Article ID:000005058
Get help from ArcGIS experts
Download the Esri Support App
