HOW TO
Find fields within feature classes and tables that are of the GlobalID data type
Summary
When working with feature classes and tables across multiple geodatabases, searching for fields of the GlobalID or GUID data type is time consuming. Hasten the process using a query. It is also important to note that the unique identifying marker for the Global ID or GUID data type is '12' in the SDE_TYPE field located in the COLUMN_REGISTRY table. Instantly identify the GlobalID or GUID fields by including a parameter in the query to search for the value '12' in the SDE_TYPE table.
Procedure
Use the following queries depending on the database type and replace the values in the queries as needed. The following queries contain examples of GUIDs. Replace the GUIDs in the queries as well.
SQL Server
SELECT A.[table_name] as 'Table Name', A.[column_name] as 'Field Name', B.[Type] as 'Feature Type'
FROM [sde].[SDE_column_registry] A, [sde].[GDB_ITEMS] B
WHERE A.SDE_TYPE = 12 AND A.database_name + '.' + A.OWNER + '.' + A.TABLE_NAME = B.physicalname AND (B.TYPE = '{70737809-852C-4A03-9E22-2CECEA5B9BFA}' OR B.TYPE = '{CD06BC3B-789D-4C51-AAFA-A467912B8965}')
Oracle
SELECT A.TABLE_NAME AS "Table Name", A.COLUMN_NAME AS "Field Name", B.TYPE AS "Feature Type"
FROM SDE.COLUMN_REGISTRY A, SDE.GDB_ITEMS B
WHERE A.SDE_TYPE = 12  AND A.OWNER || '.' || A.TABLE_NAME = B.physicalname  AND (B.TYPE = '{70737809-852C-4A03-9E22-2CECEA5B9BFA}' OR B.TYPE = '{CD06BC3B-789D-4C51-AAFA-A467912B8965}');
Article ID: 000021618
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
