HOW TO
Find dependencies in Portal for ArcGIS using ArcGIS API for Python
Summary
In some cases, it is necessary to determine the dependencies between Portal for ArcGIS items. For example, in data cleanup, a web app and its associated web map may need to be deleted. Manually checking these dependencies can be tedious. As an alternative, this process can be performed programmatically with the Administrator privilege using the following ArcGIS API for Python functions: dependent_upon() and dependent_to().
Procedure
The following steps describe how to find dependencies in Portal for ArcGIS using the ArcGIS API for Python.
  1. Import the necessary modules.
from arcgis.gis import GIS
from IPython.display import display
  1. Specify the source URL and the login credentials for Portal for ArcGIS.
source = GIS("<portalurl>", "<admin_user>", "<admin_password>")
source_users = source.users.search(query=None, sort_field='username', sort_order='asc', max_users=100, outside_org=False, exclude_system=True)
source_items_by_id = {}
print('User list: Role')
  1. Create a loop to search for all usernames in the portal.
for user in source_users:
    print(user.username + "\t:\t" + str(user.role))
  1. Create a loop to collect the Item IDs in the available folders.
    num_items = 0
    num_folders = 0
    print("Collecting item ids for {}".format(user.username), end="\n\n")
    user_content = user.items()
  1. In the same loop, retrieve the Item IDs from the root folder and check for dependencies.
    for item in user_content:
        num_items += 1
        source_items_by_id[item.itemid] = item
        print("\n\n Item: \t {2} \t\t\t id {0} is dependent on these items: \t {1}".format(item.itemid,item.dependent_upon(), item.title))
            if (item.dependent_to()['total'] > 0):
            print("\t This item is also a dependency of these items: {}".format(item.dependent_to()))
  1. In the same loop, retrieve the Item IDs from the subfolders and check for dependencies.
    folders = user.folders
    for folder in folders:
        num_folders += 1
        folder_items = user.items(folder=folder['title'])
        for item in folder_items:
            num_items += 1
    print("Number of folders {} # Number of items {} # Number of users {}".format(str(num_folders), str(num_items), len(source_users)))
The following shows the full script:
source = GIS("https://test.domain.com/portal", "portaladmin", "portaladmin")
    num_items = 0
    num_folders = 0
        num_items += 1
        num_folders += 1
            num_items += 1
Article ID: 000021183
Software:
  • Portal for ArcGIS
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
