HOW TO
Extract attachment EXIF metadata using ArcGIS Arcade
Last Published: July 31, 2025
Summary
EXIF (Exchangeable Image File Format) metadata contains important information about photographs, such as the camera's settings, time and date, and the location where a photo was taken. This information is sometimes needed to meet legal requirements of certain projects.
This can be accomplished using an Arcade expression in the Pop-up configuration, Form Calculation, Field Calculation, etc.
Procedure
The sample code below returns the date and time the attachment in the selected feature was taken.  To return all metadata in an array, uncomment out the second last line below to return the features variable.
var features = [];
var att = attachments($feature, {metadata: True});
if (count(att) > 0) {
     for (var a in att) {
          push(features, att[a].exifInfo)
//return features;
return features[0][0]['tags'][7]['value'];
The screen capture below shows the returned date and time the image was captured. Note that the index value/name will change depending on the attachment.
Arcade code to return date and time metadata of attachment.
To identify the needed index values and names, return the entire array.
Arcade code to return array of photo attachment metadata.
Article ID: 000032038
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
