HOW TO
Export a layout to PDF with editable text in ArcGIS Pro
Last Published: October 27, 2022
Summary
Creating a layout in ArcGIS Pro allows the project to be exported into various output forms, such as a printed map, poster, or PDF file. In certain circumstances, adding text to the layout and exporting it to PDF may not allow the text to be edited. This article describes the workflow to export a layout to PDF with editable text in ArcGIS Pro.
Procedure
  1. Open the project in ArcGIS Pro.
  2. Make a layout for the project. Refer to ArcGIS Pro: Make a layout for instructions.
  3. Insert text to the layout. Refer to ArcGIS Pro: Insert Text for instructions.
  4. In the Contents pane, click the Drawing Order icon.
Click the Drawing Order icon in the Contents pane
  1. Right-click the text layer and select Order > Bring to Front.
Order and Bring To Front options on the pop-up window from right-clicking the text layer Text layer showing at the top of Drawing Order list with the text appearing on the map
  1. Click Project > Save.
Project tab
Save button option to save changes in project
  1. Export the layout to PDF. Refer to ArcGIS Pro: Export to PDF for instructions.
Article ID: 000027378
Software:
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
