HOW TO
The instructions provided describe how to export each time slice from a NetCDF layer as a single raster (*.tif).
A NetCDF layer must be created in the ArcMap table of contents before NetCDF raster bands can be exported. The needed toolbox and sample data can be downloaded here: NetCDF_time_slice_to_Raster.zip
The tool exports all the time slices (bands) from the NetCDF raster layer as TIFs. The following shows the Python code used for this script tool. This code can be modified to meet various needs.
# Import modules
import arcpy, os
#Inputs
Input_NetCDF_layer = arcpy.GetParameterAsText(0)
Output_Folder = arcpy.GetParameterAsText(1)
Input_Name = Input_NetCDF_layer
Output_Raster = Output_Folder + os.sep + "NetCDF_Raster.tif"
#Copy the NetCDF layer as a TIF file.
arcpy.CopyRaster_management(Input_Name, Output_Raster)
arcpy.AddMessage(Output_Raster + " " + "created from NetCDF layer")
#Reading number of band information from saved TIF
bandcount = arcpy.GetRasterProperties_management (Output_Raster, "BANDCOUNT")
resultValue = bandcount.getOutput(0)
count = 1
arcpy.AddMessage("Exporting individual bands from" + Output_Raster)
#Loop through the bands and copy bands as a seperate TIF file.
while count <= int(resultValue):
Input_Raster_Name = Output_Raster + os.sep+ "Band_" + str(count)
Output_Band = Output_Folder + os.sep + "Band_" + str(count) +".tif"
arcpy.CopyRaster_management(Input_Raster_Name, Output_Band)
arcpy.AddMessage("Band_" + str(count) +".tif" + " " "exported" + " " + "successfully")
count +=1
# The following will delete the TIF file that was created by CopyRaster tool.
arcpy.Delete_management(Output_Raster,"#")
arcpy.AddMessage("Tool Executed Successfully")
Article ID: 000011318
Get help from ArcGIS experts
Start chatting now
