HOW TO
Export a shapefile with its symbology to ArcGIS Pro
First Published: March 3, 2020
Last Published: July 27, 2023
Summary
A shapefile must sometimes be exported with its symbology to ArcGIS Pro to share its geographic and attribute information. However, this involves a known limitation, as shapefiles do not store attribute data such as annotation, attribute relationships, and attribute domains. An exported shapefile does not retain its symbology, as shown in the image below. Refer to ArcGIS Pro: Geoprocessing considerations for shapefile output for more information.
The Contents pane displaying an exported shapefile without its symbology
This article provides a workaround to add symbology to an exported shapefile by importing the symbology as a layer file.
Procedure
Export the shapefile as a new shapefile
  1. In the Contents pane, right-click the desired shapefile and navigate to Data > Export Features. In this example, it is LandOwnership.
  2. Configure the Export Features window as follows:
    1. For Input Features, the feature layer is automatically selected.
    2. For Output Location, select the location of the output feature layer. In this example, it is Symbology.gdb.
    3. For Output Name, specify a name for the exported shapefile. In this example, it is SkiLandOwnership.
    4. Click OK.
The Export Features pane to be configured.
Export the shapefile symbology as a layer file
  1. In the Contents pane, right-click the desired feature layer and navigate to Sharing > Save As Layer File.
  2. Specify a name for the layer file. In this example, the name of the saved layer file is LandOwnership.
  3. Click Save.
Apply the layer file to the newly created shapefile
  1. In the Contents pane, right-click the newly created shapefile, and click Symbology. In this example, it is SkiLandOwnership.
  2. In the Symbology pane, click the Menu icon The Menu button symbolized by a hamburger icon., and click Import Symbology....
  3. Configure the Apply Symbology From Layer pane as follows:
    1. For Input Layer, the new shapefile is automatically selected.
    2. For Symbology Layer, select the layer file to apply to the input layer. In this example, it is LandOwnership.lyrx.
    3. Click Run.
The Apply Symbology From Layer pane to be configured.
The symbology from the input shapefile is applied to the exported shapefile as shown in the image below.
The Contents pane displaying an exported shapefile with its symbology
Article ID: 000022735
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
