HOW TO
Exit the Select tool in ArcGIS Pro
Last Published: April 29, 2022
Summary
The Select tool on the Map ribbon tab is used to select one or more features on the map. Unlike the Measure tool or the Locate tool, which can be exited from by clicking the Close button on their respective panes, the Select tool does not have a clear-cut way of exiting the tool.
This article demonstrates the ways of exiting or getting out of selection mode when the Select tool is enabled.
Procedure
Use the Explore tool
On the Map ribbon tab, in the Navigate group, click Explore The Explore icon to return to the default navigation mode when a project in ArcGIS Pro is opened.
Use the Measure tool
  1. On the Map ribbon tab, in the Inquiry group, Click Measure The Measure icon.
  2. Click Close the measure tool The Close icon on the Measure Distance window to return to navigation mode.
Temporarily switch to navigation mode when in selection mode
Alternatively, when the Select tool is enabled, press and hold the C key on the keyboard to temporarily enter navigation mode. Releasing the C key returns back to selection mode. Refer to ArcGIS Pro: Selection keyboard shortcuts for more information.
Article ID: 000027593
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
