HOW TO
Geoprocessing (GP) tools can be executed from within ArcToolbox, Model Builder or any COM-compliant integrated development environment (IDE) such as Python, VB Script or VBA. For an overview of scripting in the geoprocessing framework, please read the Writing Geoprocessing Scripts PDF on the ESRI Library CD from the installation CDs. Instructions provided demonstrate the various ways a GP tool is executed from within VBA and the ArcObjects application programming interface (API).
Please make sure that the correct object library references have been added to your project prior to running the code below.
Code:
Public Sub Test()
Dim filePath As String
filePath = "C:\Program Files\ArcGIS\Bin\TemplateData\USA"
Dim inputName As String
Dim clipName As String
inputName = "cities.shp"
Dim pGP As Object
Set pGP = CreateObject("esriGeoprocessing.GPDispatch.1")
On Error GoTo EH
pGP.Workspace = filePath
' note: the inputs can also be objects; however the output must be a string.
pGP.buffer_analysis filePath + "\" + inputName, "C:\temp\bufferfc1.shp", "1"
Exit Sub
EH:
MsgBox pGP.GetMessages(), vbOKOnly, "Test"
End Sub
Code:
Public Sub Test()
Dim pGP As Object
On Error GoTo EH
pGP.AddToolbox ("C:\PathToYourToolbox\ToolboxName.tbx")
pGP.MyModel
Exit Sub
EH:
End Sub
Code:
Sub GP_Exexute_Buffer()
'Modified from user forums
Dim pUID As New UID
Dim pAtbExtension As IArcToolboxExtension
Dim pAtb As IArcToolbox
Dim pTool As IGPTool
Dim pParams As IArray
Dim pParameter As IGPParameter
Dim pParamEdit As IGPParameterEdit
Dim pDataType As IGPDataType
Dim sValue As String
Dim pTrackCancel As ITrackCancel
Dim pEnvmgr As IGPEnvironmentManager
Dim pMess As IGPMessages
pUID = "esriGeoprocessingUI.ArcToolboxExtension"
Set pAtbExtension = Application.FindExtensionByCLSID(pUID)
Set pAtb = pAtbExtension.ArcToolbox
Set pTool = pAtb.GetToolbyNameString("buffer_analysis")
Set pParams = pTool.ParameterInfo
Set pParameter = pParams.Element(0)
Set pParamEdit = pParameter
Set pDataType = pParameter.DataType
sValue = "C:\ESRI\ESRIDATA\CANADA\Rivers.shp"
Set pParamEdit.Value = pDataType.CreateValue(sValue)
Set pParameter = pParams.Element(1)
sValue = "C:\ESRI\ESRIDATA\CANADA\Rivers_BUFF.shp"
Set pParameter = pParams.Element(2)
sValue = "500 Meters"
Set pTrackCancel = New CancelTracker
Set pEnvmgr = New GPEnvironmentManager
'Set pMess = New GPMessages
Set pMess = pTool.Validate(pParams, False, pEnvmgr)
pTool.Execute pParams, pTrackCancel, pEnvmgr, pMess
End Sub
Code:
Sub OpenGPTool()
'Dim pApp As IGxApplication
'Set pApp = Application
Dim pUID As New UID
Dim pATBExt As IArcToolboxExtension
Set pATBExt = Application.FindExtensionByCLSID(pUID)
Set pAtb = pATBExt.ArcToolbox
'First Parameter
sValue = "C:\ESRI\ESRIDATA\CANADA\cities.shp"
'Second Parameter
sValue = "C:\ESRI\ESRIDATA\CANADA\citiesZed2.shp"
'Third Parameter
sValue = "100 Meters"
Dim pCommand As IGPToolCommandHelper
Set pCommand = New GPToolCommandHelper
pCommand.SetTool pTool
pCommand.Invoke Nothing
End Sub
Code:
Private Sub UIButtonControl1_Click()
'Ensure that there are references set to the
'ESRI GeoprocessingUI Object Library and the
'ESRI Geoprocessing Object Library.
'Go to Tools > References to do this
Dim pUID As New UID
'* Use this line for custom tools or models
' Set pTool = pAtb.GetToolbyNameString("MyModel")
'* Use this line for existing tools
End Sub
Article ID:000008706
Get help from ArcGIS experts
Download the Esri Support App
