HOW TO
Enable the Census 2020 (PL 94-171) redistricting data in ArcGIS Pro
First Published: February 2, 2022
Last Published: March 24, 2022
Summary
When using the Enrich tool in ArcGIS Pro, the Census 2020 (PL 94-171) redistricting data is not displayed, as seen in the image below.
The Census PL94-171 is not displayed
This occurs because the data is not enabled in ArcGIS Pro. This article highlights the workflow to enable the Census 2020 (PL 94-171) redistricting data in ArcGIS Pro.
Procedure
  1. In ArcGIS Pro, navigate to Analysis.
  2. In the Analysis tab, under the Geoprocessing group, click Environments.
  3. In the Environments pane, scroll down and search for Data Source under Business Analyst. Click the folder icon.
Search for Business Analyst
  1. In the Business Analyst Data Source window, under Portal, click North America.
  2. Under United States, select Census PL94-171. Click OK.
Select Census PL94-171
The image below shows the data is switched to the Census 2020 (PL 94-171) redistricting data in the ArcGIS Pro Enrich tool.
The data is switched to Census PL94-171
Article ID: 000027153
Software:
  • ArcGIS Pro
  • Business Analyst
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
