HOW TO
Enable Multifactor authentication in ArcGIS Online
First Published: January 8, 2025
Last Published: August 1, 2025
Summary
Note the following:
  • Enabling Multi-factor Authentication (MFA) resets all active logins in ArcGIS Online and applications including ArcGIS Pro active sign-in, and users are forced to link their MFA from their respective smartphones through authenticator app on their respective platforms – iOS and Android.
  • This activity must be executed with proper planning considering its login impact.
  • In this case, the MFA must be disabled, an Administrator must disable it from the same option where it was enabled from security settings.
  • It requires an administrator username to the ArcGIS Online Organization Account (with a valid subscription and at least two Creator user types).
The steps to enable MFA is described below.
Procedure
  1. Log in with an Administrator username to the ArcGIS Online Organization Account (with a valid subscription and at least two Creator user types).
  2. Navigate to Organization > Settings > Security.
  3. Click Multifactor authentication in the right section.
  4. Click the Enable multifactor authentication (MFA) option button. It requires designation of at least two administrators from the ArcGIS Online organization account.
  5. Select the administrators’ users.
  6. Click Save to enable MFA. The MFA option is enabled.
  7. Click the Enforce MFA button. This enforces all users connected to ArcGIS Online account to log in again and configure their MFA using their smartphones.
  8. Once enforced, all logged-in users are notified to configure their MFA using their respective smartphones (iOS or Android).
  9. Download the respective authenticator app from iOS or Android.
  10. Scan the QR code to link the authenticator app with the ArcGIS Online Account.
  11. Open the authenticator app on the respective device to check the unique 6-digit (one-time password code).
  12. Enter the 6-digit shown on the authenticator app to successfully log in to ArcGIS Online account, as shown in the next image.
Article ID: 000034011
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
