HOW TO
ArcGIS Dashboards supports embedded content in dashboard elements. The content may vary from images and videos to website pages and more. Embedding surveys from ArcGIS Survey123 combines the visual appeal and understanding of Dashboards with real-time data editing and response.
This article describes how to embed a survey form from ArcGIS Survey123 in ArcGIS Dashboards and customize the form to edit existing data.
Note: A survey created in ArcGIS Survey123 is saved as a feature layer in ArcGIS Online by default.
Note: Users are directed to the ArcGIS Dashboards page by default. Optionally, navigate to Content and click the created web app on the item description page. On the item description page, select Edit Dashboard.
icon and select Map.
icon, and select Embedded Content.https://survey123.arcgis.com/share/<survey form ID>
Note: Add other elements as desired to the dashboard layout. Refer to ArcGIS Dashboards: Dashboard layouts for more information.
icon and select List.
and select GlobalID.Note: In ArcGIS Survey123 version 3.9 and onwards, the mode query parameter is changed by replacing the use of ObjectID with GlobalID as the means of setting feature records for updating or viewing. Refer to FAQ: What are the changes to Survey123 Web Form's Query Parameters for more information.
https://survey123.arcgis.com/share/<survey_form_ID>?mode=edit&globalId={field/globalid}&version=latest
Note: The URL is case-sensitive, in the mode=edit parameter, "globalId" must be all lower case, except for the "I" in "Id". See the Esri Community post: Global ID Parameter not provided. However the name for the value is the name of the field in the attribute table, which may be different, for example, "GlobalID".
The image below shows the data in the survey match the features selected from the List element in ArcGIS Dashboards and can be edited in the embedded ArcGIS Survey123 form.
Article ID: 000021897
Get help from ArcGIS experts
Start chatting now
