HOW TO
Edit the numeric format of a field with dynamic text in the reports in ArcGIS Pro
First Published: November 4, 2022
Last Published: November 4, 2022
Summary
In ArcGIS Pro, reports can be generated to share a well-formatted and multipage representation of users’ data. Reports are often generated on a regular basis, and in some cases, information can be added or edited in the reports. In this article, a dynamic text field named Assessed Value is edited to include a currency format in the report.
The image of the Assessed Value field to be edited to use a new currency format in the report.
Procedure
  1. In ArcGIS Pro, open the report.
  2. Click the desired field value, and right-click to select Properties.
Alternatively, expand the report subsection in the Contents pane, click the desired text element and right-click Properties to open the Element pane.
The desired field value being selected in the report in ArcGIS Pro.
  1. In the Element pane, click Text. Click the Options tab.
  2. Under Options, expand Text if needed, and click Tag View The Tag View icon.. Click field-value.
Alternatively, click Text View The Tag View icon to edit the dynamic text. to edit the dynamic text. Refer to ArGIS Pro: Dynamic text tags for more information.
The field-value being selected in the Element pane to open the Update Field Value window.
  1. In the Update Field Value window, click the drop-down arrow for Number Format and select Currency.
  2. Click OK and export the report.
The Number Format section being edited to Currency from the drop-down list in the Update Field Value window.
The image below shows the Assessed Value field with the currency format.
The Assessed Value field in the currency format.
Article ID: 000028719
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
