HOW TO
Edit the field properties of a CSV file in ArcGIS Pro
First Published: January 4, 2021
Last Published: February 11, 2021
Summary
In ArcGIS Pro, when running certain geoprocessing tools involving two or more datasets, it is necessary to ensure the fields in the datasets have similar properties. For example, when using the Append tool to append data from a CSV file to a feature class, the data type and name of the output and source fields of the field map parameter must match. Ensuring the fields match circumvents errors.
This article provides steps to manually change the field properties of a CSV file in ArcGIS Pro while maintaining the field value by editing the schema.ini file.
Procedure
  1. In ArcGIS Pro, add the CSV file to a project.
  2. Create a copy of the CSV file using Export Table. Refer to ArcGIS Pro: Export tables for more information.
  3. The new table is automatically added to Contents. To verify the data in the table fields are accurately captured, right-click the table, and click Open.
Table field view showing the columns and rows of data
  1. In Contents, right-click the new table, and click Remove.
  2. Navigate to the output file location. A schema.ini file is created with the CSV file.
Screenshot of the Windows File Explorer dialog showing the schema.ini file is created
  1. Edit the schema.ini file to change the field properties. Right-click the schema.ini file, and click Edit. Manually edit the preferred field properties (for example, data type and name), and save the changes. Refer to ArcGIS Pro: Add an ASCII or text file table for more information.
Screenshots of the original and modified schema.ini file
  1. In ArcGIS Pro, add the CSV file created in Step 2, and verify the field information. The edits to the field properties in the schema.ini file are displayed in ArcGIS Pro.
The image below shows the results of the edits made to the schema.ini file.
Screenshot of the table field views showing the results of the updated schema.ini file
Article ID: 000024378
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
