HOW TO
Edit the display name for a table element in ArcGIS Dashboards
First Published: May 17, 2023
Last Published: May 17, 2023
Summary
A table can be added as an element into ArcGIS Dashboards. The display name of the table follows the field name selected for the 'Category field' section of the element. The table name can be edited to be a custom name desired by the user. The following example displays the 'CATEGORY' field display name changed to 'Cat'.
The CATEGORY field display name changed to Cat
The article describes how to edit the display name for the table when adding the table as element or for an existing element in ArcGIS Dashboards.
Procedure
When adding the table as an element
  1. Click the Add element button The Add element button.
  2. Select the frame to insert the table element and select the Table element.
The Add element button and Table element
  1. Select the layers from the map.
  2. In the Table window, click the Data tab and select the category field.
  3. In the Table window, click the Header tab. In the Label override section, edit the Label text box.
Editing the Category text box in Label override
  1. Click Done. The table element display name is edited.
Editing the display name for an existing table element
  1. Hover over the ellipses on the element and click the Configure button.
Configure button on the table
  1. In the Table window, click Header.
  2. In the Label override section, edit the Label text box.
  3. Click Done. The table element display name is edited.
Article ID: 000030485
Software:
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
