HOW TO
An .apr file is an Object Database stored in ASCII text format, and can be edited with any standard text editor.
Warning:
Make a copy of your .apr file under a different name. You may need to revert to this backup copy in the event your edits corrupt the .apr file in any way.
(IDType.UniqueIndexNumber
ElementType: Value
(FN.234
Path: “c:/windows/temp”
(FN.234
REM Path: “c:/windows/temp”
Warning:
Never comment out (insert REM) or delete objects within an object, as other objects in the database may reference them and may cause a segmentation violation.
Article ID:000001910
Get help from ArcGIS experts
Download the Esri Support App
