HOW TO
Draw a 3D conical frustum in ArcGIS Pro
Summary
A conical frustum is a cone with a flat surface top, or without a pointed end. It can depict the shape of a mountain and can be used for general measurements, such as the surface area of a mountain top. A conical frustum can be created in ArcGIS Pro by creating two multipatch features; a cone and a cuboid. The two features intersect in a way such that the cone is cut off from the top and the final result returns a conical frustum.
Procedure
The following procedure describes how to create a 3D conical frustum in ArcGIS Pro.
Ensure this procedure is performed in a Scene layer. Both the Local and Global view can be selected from the View pane in ArcGIS Pro.
  1. In ArcGIS Pro, open the Catalog pane (View > Catalog Pane) and create two multipatch features: a cone and a cuboid. If needing assistance on how to create multipatch features, refer to the following web help document: ArcGIS Pro: Create multipatch features.
    The cuboid feature must be wider but shorter than the cone feature so that the entirety of the bottom part of the cone is preserved when the two features are processed. The image below demonstrates the multipatch features prior to creating the frustum.
    The cuboid must be oriented such that it encapsulates the entire circular base of the cone.
  2. Open the Enclose Multipatch geoprocessing tool and run the tool twice, once for each input multipatch feature. The tool generates two new features on the scene, which are used for Step 3.
    Insert and run each multipatch into the Enclose Multipatch tool.
  3. Open the Intersect 3D tool and input the features created in Step 2. Specify the output feature name and set the Output Geometry Type section to Solid. The tool returns a new feature class of a cone with the top cut off.
    User-added image
    Move, rotate, or scale the feature using the tools in the Edit pane.
    The image of edit tools in ArcGIS Pro Edit pane.
Article ID: 000016928
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
