HOW TO
The Python script provided below can be used to download PDF items from Portal for ArcGIS.
Note: This script should be run on the local Python IDLE.
#IMPORT LIBRARY from arcgis.gis import GIS #PARAMETERS #specify the path to where you want the PDFs to be downloaded #specify the Portal for ArcGIS URL #specify the Portal for ArcGIS credentials path= r"\\path\pdf" portalurl= 'https://dns.domain.com/portal' usrname = 'username' passwd = 'password' gis=GIS(portalurl,usrname,passwd, verify_cert=False) #DOWNLOAD PDFS #search for all PDF items in Portal for ArcGIS search_results = gis.content.search(query='',item_type='PDF') #download them to the specified path for item in search_results: item.download(path)
Article ID: 000028595
Get help from ArcGIS experts
Start chatting now
