HOW TO
Download ArcGIS Online hosted feature layers as zip files and extract the files using ArcGIS API for Python
Last Published: July 21, 2022
Summary
Downloading and extracting .zip files is time-consuming if many .zip files must be individually downloaded and extracted. This task can be automated using ArcGIS API for Python. The workflow in this article provides a sample Python script to download ArcGIS Online hosted feature layer items as .zip files and extract them using a stand-alone Python file (.py). The Python file also runs in Jupyter Notebook.
Procedure
  1. Import the necessary modules including the zipfile module.
from arcgis.gis import GIS
from pathlib import Path, PurePath
from zipfile import ZipFile
  1. Specify the ArcGIS Online credentials to use.
gis = GIS("https://arcgis.com", "Username", "Password")
print("Connected.")
  1. Define a function to search for all the hosted feature layers owned by a specific owner, download them as individual .zip files, and extract the .zip files to new folders for all the hosted feature layers.
def downloadUserItems(owner, downloadFormat):
    try:
        # Search items by username
        items = gis.content.search(query='owner:Owner_Name', item_type='Feature Service')
        print(items)
        # Loop through each item and if equal to Feature Service then download it
        for item in items:
            if item.type == 'Feature Service': #Feature Service is selected, since the source for Feature Layer (Hosted) type item is Feature Service
                result = item.export(item.title, downloadFormat)
                #Set the download path for the ZIP files
                data_path = Path(r'<Download_Folder_Path')
                result.download(save_path=data_path)
                #Create a new ZIP file path, new folder with the same name, and extract the ZIP files items into respective folders
                zip_path = data_path.joinpath(result.title + '.zip')
                extract_path = data_path.joinpath(result.title)
                if not extract_path.exists():
                    extract_path.mkdir()
                with ZipFile(zip_path, 'r') as zip_ref:
                    zip_ref.extractall(extract_path)
                # Delete the item after it downloads to save on space - Optional
                result.delete()
    except Exception as e:
        print(e)
  1. Call the function created in Step 3.
The downloadFormat parameter is set to 'Shapefile' as ArcGIS Online downloads shapefiles as .zip files.
downloadUserItems('Owner_Name', downloadFormat='Shapefile')
print("All items downloaded")
The code block below demonstrates the full script.
import arcgis
print("Connected")
# Download all data from a user
    try:
        items = gis.content.search(query='owner:Owner123', item_type='Feature Service')
        print(items)
        for item in items:
                data_path = Path(r'C:\Users\USER\Desktop\Download Folder')
                result.delete()
        print(e)
# Function takes in two parameters. Username, and the type of download format, in this case, Shapefile.
downloadUserItems('Owner123', downloadFormat='Shapefile')
Article ID: 000027904
Software:
  • ArcGIS Online
  • ArcGIS API for Python
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
