HOW TO
Dock ArcMap toolbars vertically
Last Published: March 30, 2021
Summary
In earlier versions of ArcMap, such as version 9.3.1, it was possible to dock toolbars vertically between the Table of Contents and the Data Frame, a shown in the image below.
toolbar docked vertically in ArcMap versions 9.x
On ArcMap versions 10.x, this capability was no longer available. This is a known limitation. Newer versions of the software use the new dockable window framework which prevents docking toolbars between the TOC and the data view.
Procedure
With the dockable window framework introduced at 10.x, it is still possible to dock toolbars vertically, but not between the TOC and the map view.
To dock the toolbar vertically, click the three dots on the left side of the toolbar and drag it to either side of the user interface, as shown in the following image:
toolbar in vertical orientation
Article ID: 000025324
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
