HOW TO
Do Custom Projections with the Projection Utility
Procedure
Where can I specify a Base Projection using the Projection Utility?
Cause:
Several of projections the projections listed as options in the Projector! extension, are not listed as standard projections for the Projection Utility. These are available as custom projections under the Advanced Options.
Answer:
A list of common Base Projections is available when you choose the CUSTOM option for Projected data. Make sure that the ADVANCED OPTIONS check box is checked, so that you can view and assign the PARAMETERS, DATUM, and ELIPSOID.
You can find the common Base Projections under the PARAMETERS tab.
The options are:
Albers
Azimuthal_Equidistant
Behrmann
Bonne
Cassini
Eckert I-VI
Equidistant_Conic
Equidistant_Cylindrical
Gall_Stereographic
Gauss_Kruger
Hotine
Lambert_conformal_conic
Loximuthal
Mercator
Miller_Cylindrical
Mollweide
Plate_Carree
Polyconic
Quartic_Authalic
Robinson
Sinusoidal
Stereographic
Transverse_Mercator
Two_Point_Equidistant
Van_der_Grinten_I
Winkel I-II
You will have to specify the geographic coordinate system, central meridian, and standard parallels for these projections.
The most commo parameters for some of these projections are:
_________________________________________________________
Albers:
Alaska, Cont-US, Hawaii, N. America
central Meridian: -154, -96, -157, -96
Ref Lat. 50, 37.5, 13, 40
Std. Parallel 1 55, 29.5, 8, 20
Std. Parallel 2 65, 45.5, 18, 60
Easting 0, 0, 0, 0
Northing 0, 0, 0, 0
geographic Clarke 1866
Lambert_Conformal_conic:
Cont-US, N. America
central Meridian: -96, -96
Ref Lat. 39, 40
Std. Parallel 1 33, 20
Std. Parallel 2 45, 60
Easting 0, 0
Northing 0, 0
Equidistant_conic:
Cont-US, N. America
Ref Lat. 37.5, 40
Std. Parallel 1 29.5, 20
Std. Parallel 2 45.5, 60
Easting 0, 0
Northing 0, 0
Equidistant_Azimuthal, Stereographic, Geonomic :
Equatorial, NorthPole, SouthPole
Spheroid: Sphere, Sphere, Sphere
Central Meridian: -72.534, -72.534, -72.534
Reference Lat: 0 , 90 , -90
Equal-Area Cylindrical: (Behrmann, Peters, Plate Carree)
Behrmann, Peters, Plate Carree,
Spheroid: sphere, sphere, sphere
Central Meridian: 0 , 0 , 0
Standard Parallel: 30 , 45 , 0
Mercator:
Spheroid: Sphere
Central Meridian: 0
False Easting: 0
False Northing: 0
Latittude of True Scale: 0
Orthographic
Spheroid: Sphere
Central Meridian: -72.5333333334
Reference Latitude: 42.533333333
Mollweide, Robinson, Sinusoidal, Miller Cylindrical,
Hammer-Aitoff:
Spheroid: Sphere
Central Meridian: 0
Notes:
All there parameters were taken from the Projector! extension defaults.
Article ID:000001556
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
