HOW TO
Divide polygon features based on selected attributes in point features
Last Published: May 5, 2020
Summary
In ArcMap, values of point feature attributes can be used to divide a polygon, and points with the same attributes can be grouped within the polygon. For instance, when studying restaurant competition of a town. Polygons can be created to represent boundaries based on the restaurant types in the attribute table, and similar restaurants can be grouped into one polygon. Although there is no single tool available in ArcMap to divide polygons based on point values, this workflow can be completed using a combination of tools; the Create Thiessen Polygon (Analysis) tool, Dissolve (Data Management) tool, and the Clip (Analysis) tool.
The Create Thiessen Polygon (Analysis) is only available with an Advanced license.
Image of an area with points to be divided
Procedure
Follow these steps to divide a polygon based on point feature values:
  1. Create polygon features around the points using the Create Thiessen Polygon (Analysis) tool.
    1. In ArcMap, open the ArcToolbox window, and navigate to Analysis Tools > Proximity > Create Thiessen Polygon.
    2. For Input Features, select the point feature from which Thiessen polygons are generated, from the drop-down list. For this example, it is Land_claim.
    3. For Output Feature Class, specify the name, and save location for the Thiessen polygon.
    4. For Output Fields (optional), select All from the drop-down list.
Image of the Create Thiessen Polygon window
  1. Click OK. Polygons are generated for each point feature as shown in the image below.
Image of Thiessen polygons generated from points
  1. Dissolve the Thiessen polygon based on the point feature attributes.
    1. Open the ArcToolbox window and navigate to Data Management Tools > Generalization > Dissolve.
    2. For Input Features, select the Thiessen polygon from the drop-down list.
    3. For Dissolve_Field(s) (optional), check the desired field(s) to dissolve the lines in the polygon feature.
Image of the Dissolve tool window
  1. Click OK. Adjacent polygons are merged based on the attribute values of the point features as shown in the image below.
Thiessen polygon after using the Dissolve tool
  1. Clip the polygon feature onto the Thiessen polygon.
    1. Open the ArcToolbox window, and navigate to Analysis Tools > Extract > Clip.
    2. For Input Featres, select the Thiessen polygon from the drop-down list.
    3. For Clip Features, select the polygon feature to be clipped from the drop-down list.
Image of the Clip tool window
  1. Click OK. The polygon feature is divided based on the point feature values as shown in the image below.
Image of an area divided based on point attributes
Article ID: 000022611
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
