HOW TO
AttributeInspector is often displayed using a pop-up InfoWindow on a web map. For more information on info window, refer to ArcGIS API for JavaScript: Class: InfoWindow. The Editor widget, however, is used to edit the values of selected features from one or more feature layers, so it is better displayed using a side panel. A side panel display is sometimes necessary to avoid limiting the window size for information.
The following code sample demonstrates how to create a side panel for the AttributeInspector widget.
var attributeInspector = new AttributeInspector({layerInfos: featureLayerInfos}, "attributeDiv");
var settings = {
map: map,
layerInfos: featureLayerInfos,
attributeInspector: attributeInspector
Note: The code sample above displays the attribute content in a DIV panel with the ID, attributeDIV.
The InfoWindow and AttributeInspector widgets must be used alternately. To begin, the initial setInfoWindowOnClick() function must be modified by changing the value to either true or false. In this case, it must be set to false. This action disables the main pop-up window for the web application, and the Editor widget is automatically enabled. This information is returned by the AttributeInspector widget using a side panel. The code snippet below demonstrates how the script looks when the Editor widget is enabled:
map.setInfoWindowOnClick(false);
Note: In general, the map.setInfoWindowOnClick() method in a specified widget function must be set to true to enable the widget to work properly. Setting the value to false is rare.
var operationsPointLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/0", {
mode: FeatureLayer.MODE_ONDEMAND,
infoTemplate: template,
outFields: ["*"]
var operationsLineLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/1", {
outFields: ["*"]
var operationsPolygonLayer = new FeatureLayer("https://services5.arcgis.com/lVkj5PBOw7tRmIPU/arcgis/rest/services/HSEC/FeatureServer/3", {
outFields: ["*"]
map.addLayer(operationsPointLayer); map.addLayer(operationsLineLayer); map.addLayer(operationsPolygonLayer);
map.on("layer-add-result", function(evt) {
switch (evt.layer.name) {
case "HSEC Pipeline Status":
featureLayerInfos.push({
"featureLayer": evt.layer
break;
case "HSEC Area Status":
break;
case "HSEC Point Status":
break;
dom.byId("getContentBtn").disabled = false;
on(dom.byId("getContentBtn"), "click", getContentBtn);
function getContentBtn() {
dom.byId("featureCount").style.visibility = "visible";
if (editorWidget != null) {
//Destroy editor widget if it already exists.
editorWidget.destroy();
map.setInfoWindowOnClick(true);
map.on("click", function(evt) {
//hide infowindow on map click because info window content is displayed in the left panel
map.infoWindow.hide();
initializeSidebar(map);
Note: The Editor widget cannot be activated if an InfoWindow function is active and the attribute is displayed on a side panel.
function initializeSidebar(map) {
var popup = map.infoWindow;
//when the selection changes update the side panel to display the popup info for the currently selected feature
connect.connect(popup, "onSelectionChange", function() {
displayPopupContent(popup.getSelectedFeature());
//when the selection is cleared remove the popup content from the side panel.
connect.connect(popup, "onClearFeatures", function() {
//dom.byId replaces dojo.byId
dom.byId("featureCount").innerHTML = "Click to select feature(s)";
//registry.byId replaces dijit.byId
registry.byId("leftPane").set("content", "");
domUtils.hide(dom.byId("pager"));
//When features are associated with the map's info window update the sidebar with the new content. connect.connect(popup, "onSetFeatures", function() {
dom.byId("featureCount").innerHTML = popup.features.length + " feature(s) selected";
//enable navigation if more than one feature is selected
popup.features.length > 1 ? domUtils.show(dom.byId("pager")) : domUtils.hide(dom.byId("pager"));
//code to handle click event on button
on(dom.byId("editingBtn"), "click", startEditing);
//start editing
function startEditing() {
map.graphics.clear();
dom.byId("featureCount").innerHTML = "";
if (featureLayerInfos.length < 1) {
alert("No layers to edit.");
return;
}, "attributeDiv");
var settings = {
map: map,
var params = {
settings: settings
editorWidget = new Editor(params, 'editorDiv');
editorWidget.startup();
registry.byId("leftPane").set("content", attributeInspector.domNode);
//snapping defaults to Cmd key in Mac & Ctrl in PC.
//specify "snapKey" option only if you want a different key combination for snapping
map.enableSnapping();
dom.byId("getContentBtn").disabled = false; //enable popup button
dom.byId("editingBtn").disabled = true; //disable editing button
Note: Click here to download a full working HTML file. The code sample in the HTML file shows the full code with the Show pop up content button available on top of the side panel. The script also provides the Start editing button for users to edit the attributes of the selected feature available on the web map.
Article ID: 000013649
Get help from ArcGIS experts
Start chatting now
