HOW TO
Display Text Only for an ICommand
Summary
When the Customize dialog box is open in ArcMap, you can right-click on a Command to set its appearance to Text Only. Instructions provided are to programmatically set the appearance to Text Only for a custom tool, or command button that implements ICommand.
Procedure
  1. Create a Visual Basic ActiveX DLL project that implements ICommand.
    Refer to the article in Related Information
  2. Remove implementation code from the Bitmap property for the ICommand:
    Code:
    Private Property Get ICommand_Bitmap() As esriCore.OLE_HANDLE
    ' ICommand_Bitmap = <do not provide an icon>
    End Property
  3. Include implementation code for the Caption property. The value of the Caption is displayed when the Text Only option is selected for a Command.
    Code:
    Private Property Get ICommand_Caption() As String
    ' Add your implementation here
    ICommand_Caption = "My Command Caption"
    End Property
Article ID:000005767
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
